M10 2.0 block on E-30 K-Jetronic Head (Please Help)!!
Posted: Tue Aug 31, 2010 1:54 pm
by Jazziat
Hello everyone,
I`m asking for your help on this topic and i will shortly explain to you the situation.
My original engine was 318 M10 EY (which i think its the Economy version) coming with the original carb (Solex 2B4) & i replaced the engine head with the E-30 injection K-Jetronic (ECU & Airflow meter).
Currently i have a problem with my block in the bearings & i need to change the block, so i thought it would be good change to look for the M10 2.0L block.
I found the hole engine (distributor) in Egypt coming from USA & after searching the internet i found the following specs:
Bore x Stroke mm: 89 x 80
Compression Ratio: 9.3 : 1
Injection: Bosch K-Jetronic (Distributor)
Max Torque: 175Nm @ 4350
BHP :125 @ 5700
What i want to do is to buy the block only and put the E-30 (K-Jetronic) head i already have on the block.
So i will be using ECU & Airflow Meter.
My questions are as follows:
1- Should i gain any more HP & Torque to the above figures from using the E-30 Head instead of the the original early head of the M10 2.0 L .
2- Will the installation be easy or i will need to change something.
3- Would this setup be good for a next step Turbo Charge application & if yes, what would be the maximum boost that should be used without risking to damage the stock internals of the M10 2.0 L block.
4- I heard that the M10 2.0L block comes originally forged internals as it was the same used in the early 2002`s.
5- Should i change the original injector`s used in the M10 318 E-30 engine (which are i guess 175 CC) correct me if i`m wrong !!
Thanks in advance for the help guys.
Jazziat.
Re: M10 2.0 block on E-30 K-Jetronic Head (Please Help)!!
Posted: Fri Sep 17, 2010 11:27 am
by J.K.jr.bad.
m10b20 piano top pistons hits e30 head. Not much but it does. So you need take a bit off of material of heads ingition camera. Comperesion after such mod in my case was 14. Not good for turbo stuff.
Posted: Fri Sep 24, 2010 1:48 pm
by tommi_e21
i have some piano topped pistons with some meat taken off the top already if your interested, but right in being useless for boost
Posted: Fri Sep 24, 2010 7:34 pm
by murran
could you not get one of those head spacer decompression plates and two head gaskets to drop the compression/clear the head?
Posted: Sat Oct 02, 2010 5:19 pm
by tommi_e21
the legion dont recomend spacer plates as they cause detonation,
i think the plate edges get to hot and cause damge, its a much cheaper way of doing it though
Posted: Sun Oct 10, 2010 10:07 am
by Jazziat
very wired J.K.jr.bad, i thought that the M10 B20 pistons as low compression .... :(
But anyway ... i have a good idea .... why not putting my pistons (which are already low compression coming from the M10 B18 EY block) its the same bore 89mm
I guess by doing so, i can lower the compression to 9.5 or something .... do you know any info regarding this.
And, regarding the spacer idea .... i think its easy to do so ..... one of the options i guess .. thanks murran.
However, i agree with austin25uk about the damge coming from using a spacer plates .... maybe i can use them only as a last option.
so, again .... i`m lost .... should i do this swap .... or its better to rebuild my M10 B18 and go for a little bit high revs .... using the benefit of shorter strock ... and turbo charge the engine while doing some head port & polish job ????
i guess all the help is needed from you guy`s .... you are the expertees here
BR
Jazziat
