LSD on ebay need opinions
- quinn_656
hi guys came across this today im on the hunt for a diff any (quick google) research ive done say the e21 has the this 168 diff
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
what are your thoughts?
My build
www.quinnpiling.com
www.quinnpiling.com
- Jason_323i
Re: LSD on ebay need opinions
Niel is a good bloke so lsd will be okay, but you need to pay a good transmission shop to put in an e21 case, normally about 200-250 inc new seals and bearings.
I have a few contacts
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
That's a lot for the gubbins only. I paid quite a bit less for an e21 LSD complete and in excellent condition delivered from the USA. Check American ebay before commiting to that.
Do you just need a diff? ROb will probably have one or two spare.
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
- e21-Mark
- E21 Master
German ebay too. There's one for 600 Euros I think?
I seen one on there for 599. I was biddin on a motorsport steering wheel but that went for £348!! Are they that rare?
- e21-Mark
- E21 Master
I was watching that steering wheel myself. £356!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 942wt_1141
- quinn_656
guy said its an e36 small case could get a guy to build it for me though dont think its cheap at 450 for what it is.
does anybody know of anything else for sale thought american ebay by the time you add postage vat and import duty wouldn't be worth it. do you have any details for rob really it is only the clutch pack that i need.
My build
www.quinnpiling.com
www.quinnpiling.com
just weld up an open and never think about lsd's again!
igot that steering wheel in my car if anyone wants to buy it from meRetroBeemer wrote:I was watching that steering wheel myself. £356!!
Audi 50 RS
Audi 50 RS
- e21-Mark
- E21 Master
- quinn_656
Re: LSD
Yes that’s the road I went down good thread too. I gave £300 for the e36 LSD with new clutch plate things in it guy was real helpful too he showed me how to split and build the diff. they are rebuildable the plates are type 004 ZF plates (same as mk2 escort plates) they can be easily got i give my local Hydraulic man £20 to get me new seals including spares. What I did differently to that guy was I ground away the casing from both sides i think it is a better job. Stronger and seals better. Their really is only a couple of mm in it the open diff has flat spots (windows) which let it twist up out where as the LSD is a solid cylinder apart from the windows they are identical in size. i swapped the side bearing races to match the e36 side bearings. i am however going to swap the crown wheel and pinion for a 3.91 set or 4.10 whichever comes in a 316. i think that 3.45 is a bit tall
I also learned that to work out the diff ratio u just count the teeth on the small cog (pinion) and divide that into the number of teeth on the big ring gear (crown wheel)
i think that the e36 diff is a good option because it really only came on the later 318's so its much fresher than an e21. Its also much cheaper and because you have to grind a little casing away the diff unit must be a little bigger therefore better (but don’t quote me on that)
My build
www.quinnpiling.com
www.quinnpiling.com
- e21-Mark
- E21 Master
Anyone got any leads to a good diff man near London?
- Jason_323i
Kent Tranmissions, rebuilds boxes/diff fro a lot of the khumho guys or G Sport who are more britcar/GT so cost a bit more
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
