323 front struts
pro-street beemer
323 front struts
Post by pro-street beemer »
hi,just a quick question.do 323 struts fit a 316 car or do i need to change steering arms etc.thanks
Mihajlo
My E21(s): 1982 315swap323i
Re: 323 front struts
Post by Mihajlo »
they fit.
difference is in a diameter.
pro-street beemer
Hi, thanks for getting back. Please can you tell me what diameter you are referring to & will they fit a 316 steering arms & anti rollbar ?
Jason_323i
Post by Jason_323i »
only the strut diameter and bearing size
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
quinn_656
Post by quinn_656 »
the 323i struts are 51mm as opposed to 45mm on your 316 you will need to use your 323i hub if the bearing is bigger
My build
www.quinnpiling.com
redline
Post by redline »
Not that simple. You will need to fit a 323 strut housing to the 316 or any other model for that matter. The 323 front suspenion is unique.
