Converting a e21 320 to fuel injection
e21baur1984
Post by e21baur1984 »
Hello guys new to the forum and i would appreciate some of your help!!
I have a 1981 320 baur auto and a 1979 320 manual both on nasty pierburg carbs!
now as the summer is approaching i would like to use the Baur but im intending to convert it to e30 motronic injection, could anyone be kind enough to post a list of items i will need so i can start sourcing the bits before i start stripping the old girl down. all your help is very much appreciated!!
DrGonzoPOW
Re: Converting a e21 320 to fuel injection
Post by DrGonzoPOW »
Inlet manifold, fuel rail, regulator, injectors, throttle body
Rocker cover with mounting bracket
ECU
Air flow meter
Crank pulley and position sensor
Engine loom
Fuel pump
Rotor, dizzy and ht leads
Air filter/adapter kit
Where do you live ? May have alot of these parts i dont need anymore.
Wakefield Hellfire
J.K.jr.bad.
My E21(s): BMW 315, BMW 323
Post by J.K.jr.bad. »
If you have one fuel line, then you should instal second one that returns excess of fuel back to tank. In this case you either should modify fulel leverer in tank or get one from any e21 injection version.
J.K.jr.bad.
e21baur1984
Thanks for your replies, think i have a return line on mine but will check, i live in se london and work in sevenoaks kent would be interested in purchasing some bits if you have them want to get this one out for the summer!!
DrGonzoPOW
Well im a few miles off near leeds mate! But maybe able to help you out with a few bits. I have an 81 320/6 and it has feed and return lines
Wakefield Hellfire
