best brake upgrade for a 316...
mk1magic
Post by mk1magic »
Hi, Im thinking of upgrading my brakes as the standards are shot. Dont want to go mad as i dont have a welder to start welding up brackets etc etc
Cheers
Arron
Re: best brake upgrade for a 316...
I'd do a rebuild on the existing calipers first, that might already do miracles.
DC
Post by DC »
I would suggest you complete setup from 323i - calipers and vented rotors - it is bolt on update
Image <- 320i Turbo
Reck
Post by Reck »
Is there a big difference between 323i and 316 fronts?
mk1magic
Post by mk1magic »
Nice 1 anyone got a set kicking bout...? ,)
Tato
My E21(s): 1980 E21 316/1 manual
Post by Tato »
Reck wrote:Is there a big difference between 323i and 316 fronts?
Only when you use it constantly, because they are ventilated.
The calipers are the same, 323i have a spacer, because the rotors are wider.
Same pads.
Best upgrade for a E21 316, is E21 323i front and rear brakes.
1980 316/1
