320/6 Distributor Timing, Help!
Dan320is
Post by Dan320is »
Hi guys.
I've got a 320/6 and I'm unsure where to align the distributor timing at TDC?
Can anyone help?
Cheers, Dan.
OCD in detailing.
Re: 320/6 Distributor Timing, Help!
I do not know what is your question exactly but i think you want to know where to check the timing with the testlight?
At the front of the engine at the crankshaft is a timing indicator which must line up with a marking on the bottom of the engine. You can see this from the alternatorside down below. You must know what degrees before TDC you must have and at which rpm's.
Dan320is
Post by Dan320is »
Well so far the new timing belt is on and everything is timed up except for the distributor, the car starts but runs with a misfire/in the wrong firing sequence.
As far as I know the distributor hasn't been moved. Could the distributor need moving? The new rotor arm and cap were replaced in a sequence to stop any errors.
Any ideas guys?
OCD in detailing.
murran
Post by murran »
are you sure the dizzy hasnt moved? its driven off the larger pulley (than the crank pulley) next to the crank pulley to the right.
did you mark this pulley up so you know it hasnt moved? if its not running as well as it did before you changed the belt then yove got it a tooth out. if you start moving the dizzy body to correct the timing, but then you'll need a timing light to set it up correctly.
set it up on tdc on the mark on the crank pulley. pull the dizzy cap off, if you didnt notice before, theres a little line cast into the metal on the edge the dizzy body, this is supposed to line up (pretty much) with the rotor arm and the no.1 electrode (wrong term for it, but you know what i mean).
check this!
