K-Jet diagnosis - engine cuts out
E21meister
Post by E21meister »
The last few times driving The BOL (my standard E21 323i with K-jet), the engine cuts out on the motorway and has all of the hallmarks of fuel starvation; it doesn't just stop, the engine splutters like you've either blocked the air intake or you're running out of fuel. If I turn the ignition key off & on again, it starts up fine, which seems to indicate something electrical being reset.
Is this the first signs of the the fuel pump giving up the ghost, or something more k-jet related?
Mihajlo
My E21(s): 1982 315swap323i
Re: K-Jet diagnosis - engine cuts out
Post by Mihajlo »
check the fuel pump first..
it may be giving up. :|
