Jacking
Posted: Wed May 11, 2011 10:30 pm
by cdavie2002
I think this has happened to all our cars at some point in their lives. Car goes to garage, they use a flat plate on jack to lift the car up. The weight of the car then crumples the bottom of the sill.
How can we avoid this?
Re: Jacking
Posted: Wed May 11, 2011 10:43 pm
by DrGonzoPOW
Stand over the garage monkeys and make sure they use the cross members/sub frame ! Or dont take it to a local garage where they dont give a s%^t
Re: Jacking
Posted: Thu May 12, 2011 12:26 am
by PeteK
Take a large piece of timber with you. You can either use it to spread the load or to beat the mechanic. Your choice
Re: Jacking
Posted: Thu May 12, 2011 12:46 am
by arshad76
PeteK wrote:Take a large piece of timber with you. You can either use it to spread the load or to beat the mechanic. Your choice
Ha ha great advice, kind of a dual function thing. A proper hydraulic ramp is also safe I reckon.
Re: Jacking
Posted: Thu May 12, 2011 3:18 pm
by cdavie2002
All valid points guys, cheers. I especially like this idea
I hust wondered if there was a rubber pad that could be used to protect the sills.
Re: Jacking
Posted: Thu May 12, 2011 4:17 pm
by Jason_323i
You can also get a selection of rubber pads with cutouts to sit around the sills that fit the jack pads, I am actualy suprised more garages do not use them.
Or go extreme like and stick a cage in with steel plates welded under the cage mounts to act as jacking points
Jason
