Jacking
cdavie2002
Jacking
Post by cdavie2002 »
I think this has happened to all our cars at some point in their lives. Car goes to garage, they use a flat plate on jack to lift the car up. The weight of the car then crumples the bottom of the sill.
How can we avoid this?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
DrGonzoPOW
Re: Jacking
Post by DrGonzoPOW »
Stand over the garage monkeys and make sure they use the cross members/sub frame ! Or dont take it to a local garage where they dont give a s%^t
Wakefield Hellfire
PeteK
My E21(s): 1979 323i Euro
Re: Jacking
Post by PeteK »
Take a large piece of timber with you. You can either use it to spread the load or to beat the mechanic. Your choice :hammer
Pete K
'79 323i (for good times)
'81 M535i (for collecting)
'75 520i (track machine)
'03 320i (for commuting)
'97 Laser
arshad76
Re: Jacking
Post by arshad76 »
PeteK wrote:Take a large piece of timber with you. You can either use it to spread the load or to beat the mechanic. Your choice :hammer
Ha ha great advice, kind of a dual function thing. A proper hydraulic ramp is also safe I reckon.
UK Moderator
cdavie2002
Re: Jacking
All valid points guys, cheers. I especially like this idea :hammer
I hust wondered if there was a rubber pad that could be used to protect the sills.
Chris
1975 3.0 csi
2003 E46
Jason_323i
Re: Jacking
Post by Jason_323i »
You can also get a selection of rubber pads with cutouts to sit around the sills that fit the jack pads, I am actualy suprised more garages do not use them.
Or go extreme like and stick a cage in with steel plates welded under the cage mounts to act as jacking points
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
