New BMW E21 owner! Dashboard backlight problems, advice : )
p4uke
Post by p4uke »
Hello
Iv have just recently purchased last week my BMW E21 316, 1780cc, 1983, Red (I have some images but not sure how to post them)
The only problem which i am having is the dashboard backlights aren't working when the headlights are on, all the other warning lights are working fine, I just cant see the speedo and rev counter at night. Is this just a few bulbs that may be out? if so is it an easy job the replace the bulbs, i have checked all the fuses, all seem ok.
Any help would be greatly appreciated and also any other tips I may need to know
BMW E21 316 1983
johne21
Re: New BMW E21 owner! Dashboard backlight problems, advice
Post by johne21 »
Hello
have you tried turning the dimmer on the headlight switch ?
1976 e21 320i A4 Alpina #1755
p4uke
Post by p4uke »
Hi
Yes i have done that, well, to be sure the dimmer switch is the on the headlight pull out switch? do you just twist it?
BMW E21 316 1983
Yes mate, just twist it and your dash lights should get brighter. Actual failure is pretty rare.
p4uke
Post by p4uke »
yes iv done that, still no dash lights
BMW E21 316 1983
Fuses? Roll them in their holders as they can corrode and break contact without blowing.
p4uke
Post by p4uke »
iv cleaned each fuse with a fibreglass pen
BMW E21 316 1983
You need to check there's power reaching the light switch and/or bulbs then.
Perhaps the bulbs are all dead. There are three located above the cluster, requires removing the cluster.
