Page 1 of 2
Bushes, bushes and more bushes
Posted: Tue Jul 12, 2011 10:03 pm
by Reck
I really need help getting this right as my MOT depends on it, any advice willl be much appreciated. My mechanic gave me this list;
4 Bushes Rear Lower Arms
I take it he means part no. 33329061945?
no. 3 on this diagram
Why do the OEM bushes and the superflex ones look so different??
Image vs. Image
Re: Bushes, bushes and more bushes
Posted: Tue Jul 12, 2011 10:08 pm
by Reck
2 Centre Bushes for Front Stabiliser
I take it he means part no. 31351126577 ?
no. 2 on this diagram
I measured the diameter of the bar (1981 316 1.8 RHD) and I *think* it's 23.5mm
Posted: Tue Jul 12, 2011 10:12 pm
by Reck
2 Bushes Front Stabiliser to Track Control Arms
I take it he means part no. 31121123037 ?
no. 16 on this diagram
Posted: Tue Jul 12, 2011 10:19 pm
Bushes for the rear trailing arms aren't that different but the tubes are shown separate on the superflex pic, these are inside the oem ones as well.
Bushes for the front arb, if he says center I guess he means those, the other ones are those in the front trailing arms as per your 3rd post, seems like the correct P/N as well. ARB diameter of the front arb should be 23,5mm indeed.
I'd consider replacing the front arb rings on each side of the control arm as well, originalle they have rubber on them and it is likely that rubber is gone now. The rubber helps close in the control arm more to prevent shimmy. I even went one step further and added the old rings to the new ones to close in the control arm even more for sharper steering, goes well without any clunks or side effects. Pic:
Posted: Tue Jul 12, 2011 10:36 pm
by Reck
Cool, thanks for the advice Jeroen. Do you have a part number for those rubber rings?
Posted: Tue Jul 12, 2011 10:52 pm
The rubber is melted onto the no 8 front arb ring I believe. Two new ones of those and you can use the old ones together with those new ones. I made the holes slightly wider to move them up the arb bushing tube (right on my pic).
Posted: Tue Jul 12, 2011 11:00 pm
by Reck
Ah no. 7 and 8. Thanks for the advice, kind of thing only an E21 enthusiast would tell you! :D
Posted: Tue Jul 12, 2011 11:08 pm
Well now I'm thinking of it I'm not sure which one has the rubber on it, perhaps better order two of each (#7+8)...
Posted: Tue Jul 19, 2011 7:27 pm
by Reck
Just for future reference if anyone wants the rubber coated washers they are part no. 31351123140 :)
Posted: Tue Jul 19, 2011 8:22 pm
Good to have that cleared up. All set now?
Posted: Tue Jul 19, 2011 8:49 pm
by Reck
Ooops, rubber coated washers, not rubber coated bushes*
Well, it's the bushes sorted! Thanks again for the help.
Most welcome! Keep us posted on the end result, how does that improve the ride?!
Posted: Tue Jul 19, 2011 8:51 pm
by Reck
I will. The ride has gotten pretty terriblein recent weeks.. Wheel shimmy, pulling to the left when braking, horrible crashing and squeaking over bumps. Not very comfortable at all!
Posted: Thu Jul 21, 2011 10:50 pm
by arshad76
Hiya, not sure if you need any bushes for the rear antirollbar. I ordered some poly and they didn't fit! If you need em let me know and if they fit, just pay me what you feel like :)
Posted: Sun Jul 24, 2011 7:53 pm
by Reck
Hi buddy, thanks for the offer! I've been meaning to stick my head under all week but I don't think I've got a rear ARB since it's a 316?
