cams
quinn_656
cams
Post by quinn_656 »
hi guys how do this sound? i was considering something for my m20b27 engine that i building.
BMW E30 325i Schrick 272 & Kent 277 "Sports R" Camshafts
have a schrick 272 and kent 277 up for grabs here, will sell both outright or may straight swap one for a fit LSD for my 325i. any LSD with gearing of 3.73 or lower would be considered (dont fancy anything geared higher than 3.73). both cams have seen very little milage before being removed as there is absolutely no notable wear on the lobes of either cam.
Schrick on the top, Kent on the bottom:
Schrick Specs:
duration - 272 degrees
cam lift - 7.0mm
valve lift - 11.0mm
valve timing - 25/67 67/25
valve lift at TDC - 1.6mm
valve clearance - 0.25mm/0.25mm
full lift - 111 degrees
cam is in excellent condition with only some extremely light surface corrosion/discolouration towards the rear of the cam from sitting on a shelf for years. bit of emery cloth or very fine sand paper would take that off and leave the cam in "as new" condition.
£245
Kent 277 "Sports R" Specs:
duration - 277 degrees
cam lift - 7.01mm
valve lift - 10.66mm
valve timing - 27/70 70/27
valve lift at TDC - 1.57mm
this cam is also in excellent condition with no notable wear on cam lobes. looks to have seen even less use than the schrick.
£275
may consider reasonable offers on both and can post at buyers expense
My build
www.quinnpiling.com
quinn_656
Re: cams
Post by quinn_656 »
they are up for sale on a local forum that i'd be on now and again i'm not really sure what sort of cams i should be looking out for for my engine was hoping some of the more experienced lads could advise
My build
www.quinnpiling.com
