Head Gasket replacement
Posted: Thu Sep 15, 2011 10:51 pm
by bmwdenis
Help here .. I have a 1983 m10 e21 320i .. i have removed everything for the head gasket replacement .. have al the gaskets to replace everything i think . however there are 2 hose connections i have not found where they go..
one on the back of the head closest to the firewall.. sticking out of the head and the other seems to be a water hose coming off the back of the water punp line headed to the heater..
Any help here would be appreciated
Thank you
Re: Head Gasket replacement
Posted: Fri Sep 16, 2011 5:54 am
by bmwdenis
Here are the pictures of the 2 hose locations i was talking about .. anyone out there ???
appreciate any help here..
Thank you
Posted: Fri Sep 16, 2011 9:45 am
by Peter V.
Your pictures i can't see but it could be that you the hoses are for the heater of the car. The connecttions comming through the firewall.
The heater has two hose-connections. One from the head and one from the thermostathousing.
The hose from the head is the feed towards the heater. In the 320/6 and 316 of us there is a valve between which is connected with the panel inside for the temperature of the heater. There are type's of heaters that that valve is inside the car on the inner side of the firewall.
Posted: Fri Sep 16, 2011 10:04 pm
by bmwdenis
the one is actually on the block no ton the head its a small hose, the one from the back of the water pump is as well
the site wont let me post the pictures unless osmeone can tell me how
Thank you
Posted: Sat Sep 17, 2011 10:57 am
by DrGonzoPOW
Upload them to photobucket.com then copy and paste the IMG code/address that should be displayed below the photos in the gallery once they are uploaded. It should look like this....
[IMG]http://i343.photobucket.com/albums/o456 ... C00740.jpg
Ive deleted the last part so the photo wont display but if you just paste that code into this text box it should show your picture
Posted: Sun Sep 18, 2011 5:01 pm
by bmwdenis
here are the pictures i hope ..lol
Hope you can see them and give any help on where these last two hoses go..
Thank you
Posted: Sun Sep 18, 2011 8:38 pm
by murran
do they go to the throttle body? some throttle bodys have a coolat heat bit in them....
Posted: Sat Oct 08, 2011 3:32 pm
by redagain
the small outlet closest to the front of the car runs to the underneath of the throttle body. The one closest to the firewall runs to the side of the throttle body.
