284 cam valve springs
quinn_656
Post by quinn_656 »
When putting a 284 schrick camshaft into a 325i head is it neccesary to upgrade the valve springs aswell? schrick reccomend it but why? what is the difference, risk etc?
When the block has been decked by 2mm is there any way around a vernier pulley to set the timing?
Willy
My build
www.quinnpiling.com
quinn_656
Re: 284 cam valve springs
Post by quinn_656 »
any thoughts on this guys?
My build
www.quinnpiling.com
I have a 282° dbillas cam in my 2.7 conversion and I used the upgraded springs, if your car isn't going to rev higher than 6500 rpm than this is not really needed (never bad to upgrade them anyway) if its going to rev like my 2.7 stroker up to 7000rpm than it is best to upgrade.
As for the adjustable pulley you will certainly need that because the ignition is fix on the head and the distance between cam shaft pulley and crackshaft pulley is also fix due to the lenght of the timing belt .. if you change that distance by 2mm than you can not go around the adjustable pulley otherwise ignition will be set to late :wink: .. timing belt will be ok because of the tensioner
Gerrit
quinn_656
Post by quinn_656 »
thanks gerrit i would like my engine to rev out suppose its best to go for the springs as well then.
My build
www.quinnpiling.com
