Drive shafts and Cvs etc the same 323 - 316
problemchild75
Post by problemchild75 »
Before I start. Are the driveshafts cvs etc off my 316i going to fit the 323 rear / hubs / discs? Tia
TIA
Jamie
Also check out the rear hub nut for factory fresh. Should I really be ripping it to peices lol
Mihajlo
My E21(s): 1982 315swap323i
Re: Drive shafts and Cvs etc the same 323 - 316
Post by Mihajlo »
there are fiew different driveshafts...
1. 4cil engine with 4 speed gearbox
2. 4cil engine with 5 speed gearbox also sport gearbox
3. 4cil engine with automatic gearbox
4. 6cil engine with 4 speed gearbox
5. 6cil engine with 5 speed gearbox also sport gearbox
6. 6cil engine with automatic gearbox
actual difference is in front part of driveshaft and if it haves 3 or 4 bolts to attach to gearbox
and difference is if it is early or late model...
http://bmwfans.info/parts/catalog/E21/S ... ive_shaft/
Jason_323i
Post by Jason_323i »
There is a very good chance they are different but depends on the year of the car.
Your okay you do not have to touch the hub nut to swap the parts over
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Now lads don't mess up the language here :D Mihajlo refers to propshafts and there he's correct. When we're talking driveshafts, as of Sept 1978 they're all the same and all the same length for all E21's.
All the same? Well, BMW used different setups with fillers on either side (but same length overall) and with two types of flanges on the diff, but generally ur ok.
Mihajlo
Post by Mihajlo »
yes, you are right! :)
driveshaft's are different, but output shaft's are all the same.
