Car won't start?
silver-stue21
Car won't start?
Post by silver-stue21 »
Tried to start the car after three weeks standing and it wouldn't start. The battery is good and its turning over fine but it just wont fire up.
I gave it a service, changed the plugs and fitted a performance filter the other week and it was running fine, my first thought was either blocked fuel pipe or pump, although what do i know.
Any thoughts and what else to check before i summon a pro?
BMW e21 323
Chipped Audi A3 TDI Sport
Re: Car won't start?
What model is it?
After an starting attempt, get a starterplug out en look whether it is wet or not. When it is not wet, there is no fuel getting in the cilinder. When it is wet, there is no spark.
silver-stue21
Hi Mark, its an (m10) 316.
Cheers Wilmo, i will check that out tomorrow also!
BMW e21 323
Any joy?
where are you based? Maybe someone close by could have a look for you?
silver-stue21
Just outside Newbury, gonna have a tinker tomorrow n double check the fuel situation as the needle does have a habit of lying at times, don`t want to look like an arse! e_surprised
BMW e21 323
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
Try spraying easystart in the carb
silver-stue21
I did have a tinker the other day n checked the plugs and i think its a spark problem.
Got the local grease monkey popping over to collect the car in the morning for some tlc :-)
BMW e21 323
