rear suspension question
Posted: Thu Oct 25, 2012 4:14 pm
by jimbob
Changed my rear springs the other day and there was two
Sets of holes for the top mounts I just wondered why and
Wich ones should be used
Re: rear suspension question
Posted: Sun Oct 28, 2012 1:24 pm
by jls7
I don't believe it matters which you use, but one set line up with holes in the metal above so you can actually access them with a socket wrench from above (just remove the back of the rear seat - and possibly a punch through a tiny bit of sound insulation), which makes it far easier to install/uninstall. Also, that same set I think are easier to access with a spanner too.
Posted: Mon Oct 29, 2012 4:05 pm
by jimbob
Oh good nothing to worry about then I wasn't sure if someone
Had made them for different rear shocks.thanks for the reply
