rear suspension question
jimbob
Post by jimbob »
Changed my rear springs the other day and there was two
Sets of holes for the top mounts I just wondered why and
Wich ones should be used
E36 328i Daily driver
E36 328i Touring
jls7
Re: rear suspension question
Post by jls7 »
I don't believe it matters which you use, but one set line up with holes in the metal above so you can actually access them with a socket wrench from above (just remove the back of the rear seat - and possibly a punch through a tiny bit of sound insulation), which makes it far easier to install/uninstall. Also, that same set I think are easier to access with a spanner too.
jimbob
Post by jimbob »
Oh good nothing to worry about then I wasn't sure if someone
Had made them for different rear shocks.thanks for the reply
E36 328i Touring
