5 stud convention on 323i
Re: 5 stud convention on 323i
For once try to post your Q's in the right forum. And did you try the search function yet?
- Jason_323i
I have done a couple of times
Front e12 hubs
rear welder & tape measure and a rear axle of your choice
Front e12 hubs
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- e21-Mark
- E21 Master
This isn't a 5 minute job bolt-on job. If memory serves, there is also some machining to be done? I think the e12 hub comes in 2 sizes and m535i ones have a larger bearing. Also the hub is longer than an e21 on so it changes the front track. The centre bore of the e12 brake disk is smaller than the later 5 stud cars, so you'll need spigot rings. I was going to do this (when I thought about buying Jason's old 5 stud set-up) but it's just too much grief for me. That's why I got PCD adaptors instead.
If you Google ''e21 to e12 hub conversion'' there's plenty of old info (much of which is by Jason as he's done more of this sort of stuff than most. (When it comes to e21 he's a sick man
If still determined, you could ask Arshad if he wants to part with the hubs etc, from the e3 he's just broken up?
Fosters banned for 7 days as I'm not hired to keep on correcting his posts.
