Things to replace while struts are out?
trash-berd
- My E21(s): '82 320i US Manual 1.8L
- Facebook page: https://www.facebook.com/eli.tripi.5
I'm planning on replacing the shocks on my 320i this weekend. Is there anything that should be replaced at the same time, or that I should look for wear on while I have to take that much stuff apart?
Re: Things to replace while struts are out?
A few checks that come to mind:
- top bearing for freeplay (decompress spring and have a feel before dismantling the rest)
- dustcaps on balljoints
- drain hole at the bottom spring plate open
give extra attention to the sequence of the o-rings around the top bearing, affects wear and steering!
Alse see this topic http://www.bmwe21.net/forum/viewtopic.php?f=3&t=19618 as referenced in the FAQ section
