Electrics on the steering wheel
raseeda green
Post by raseeda green »
Hi all
I having a problem with the indicators and push horn, it happens often, then it stops again, but its been off for days now... the indicator buzzes from the relay but when I check the hazards still work! This is so bad as other drivers think I'm being arrogant and a road hog then
full beem still works but not the indicators or the horn?.? I guess it's loose wiring, but would this mean removing all the steering wheel? And is it hard to do?
Please help
Thank you
316 auto raseeda green
323 red m52 modified
Re: Electrics on the steering wheel
Same fuse, did u try a good old fuse twist party? Also see http://www.bmwe21.net/?page_id=130
raseeda green
Thanks Jeroen,
I'm invited to this party this weekend, so will have a go, I think I'm just gonna undo it all and clean it up inthere to start off, with..
Sean
My E21(s): 1981 323i Auto
Post by Sean »
Raseeda,
Di you have any luck with the horn?
I have the same problem. I've pulled the relay out, given it a quick sand on contacts and checked the fuse.
Still no joy. Any takers?>
Just the horn? Could be the contact between the steering wheel and the steering column, or the wire came off the push button
Sean
Post by Sean »
Jeroen,
Its an original 4 spoke wheel so no push button.there is contact between wheel and column.i have taken the steering wheel off a few times so i might try re instllibg.
