valve seals
Saphire
My E21(s): '76 316
valve seals
Post by Saphire »
Is the possible to change valve seals without removing Cylinder Head?
A.P.V.
Re: valve seals
Post by A.P.V. »
in a M10, no.
in a M20, yes
Corrado
My E21(s): 1982 320i, manual with air
Re: valve seals
Post by Corrado »
Not entirely true. Begin with the piston at bottom dead center, just before the compression stroke. Remove the spark plug and feed a length of rope down into the cylinder. Once you have loosely filled the cylinder with rope, begin to turn the crankshaft in the normal direction until resistance is felt. Now with your spring compressor, you can push down on your springs without worry that your valves will drop inside the engine.
