Hard to start the engine cold
ians320is
My E21(s): '83 US 320is 5-speed
Post by ians320is »
I'm having trouble starting my car when its cold, it idles very low and has trouble not dying. However once it warms up the idle balances out and is totally fine. I was told I need to replace the "cold start injector" which makes sense, but could it be anything else these seem kinda pricey? Thanks, Ian
Re: Hard to start the engine cold
You can start by testing it! Take it out and see if it works on a cold start. Does it get switched electrically? Be careful with the fuel line that may have become brittle over the years.
ians320is
Post by ians320is »
I'm not really sure where its located, what it look like, or how to test it... :lol: if you could point me in the right direction that'd be awesome.
PeteK
My E21(s): 1979 323i Euro
Post by PeteK »
If you have the later intake manifold, It goes into the manifold on the side of the "square block".
If you have the earlier "banana" style manifold, it is just ahead of the throttle butterfly.
Pete K
'79 323i (for good times)
'81 M535i (for collecting)
'75 520i (track machine)
'03 320i (for commuting)
'97 Laser
polov8
Post by polov8 »
The cold start valve, 5th injector, or whatever is controlled by the thermo time switch which shuts off the power to the injector as the engine begins to warm up. so if the injector seems none functional, that's worth testing too. If the roughness lasts longer then the Aux air valve or Control pressure regulator could be your issues. I'm a noob, but I've been messing with VW's with K-jet for nearly 20 years.
This is a good page that shows all the parts of the system and their function:
http://www.lexam.net/peter/carnut/320parts.html
How long does the rough running last? Seconds? Minutes?
Andy
