Idle
- Heinrich
- My E21(s): '81 323i TC-1 Baur 5-speed
Idle
Hi everyone. Please listen to this:
When just starting there is no problem. When warm no problem either. So between start and full temp. it runs up and down when ideling. When speeding up it's like not all cyl. are comming along at the same time.
Any idea what it coursing this?
Re: Idle
Could be a vacuum leak, but in most cases a incorrectly adjusted CO is the cause. You just did a long trip and that may have had its influence (cleaned things up). Have the CO checked, make sure it's in the 1.5-2.5% range and usually that solves the issue already.
Re: Idle
http://bmwfans.info/parts/catalog/E21/S ... ow_sensor/
Under the number 5 cap is a hole. Here the adjustmentscrew is located. (Most likely will not find the cap anymore and it is just a hole).
Re: Idle
It's a 3 mm allen (google translate????)
Re: Idle
So i could better said it in Dutch then "Imbus".Malthe wrote:Here we call it Umbraco, so I did understand![]()
Thanks to both of you!
Rgds.
Good luck with it.
- Heinrich
Re: Idle
Since I don't have licensplates on the car yet, I can't go to a garage to have the CO ajusted. They took a test when I was at the MOT. It was only 0,6-0,7. I just tryed to adjust the screw a little and it is VERY sensitive. Even by touching the screw the engine changes performans and sound. First adjusting one 1/4 and it ran fine again. Then only by touched the imbus it started to rool again. Should it be that sensitive or do I miss a gasket or something?
Re: Idle
Nope, they are that sensitive. You can make it run a bit better using just your hearing now but it needs a CO/exhaust gas analyzer and a steady hand haha
Re: Idle
Make sure you turn the screw just a little bit. 1/4 is a big adjustment already.
When you measure it remove the umbraco because the weight alone is enough to give the wrong figures.
Re: Idle
850 to 900 rpm
