Brake fluid level
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Brake fluid level
Post by AndyBaur »
I've just been bleeding my brakes with a pressure bleeder. This had left the master cylinder over full. I've removed quite a bit of excess fluid but the "pop-off" valve is still up.
Should this be up or should it be level with the top of the cap?
AndyS
Re: Brake fluid level
That is not a pop up valve but a level sender, in this case with a ripped top seal. You can order a new cap from the dealer as this will leak like hell and brake fluid is quite devastating stuff
AndyBaur
Post by AndyBaur »
Thanks for the heads up!
AndyS
