Brake fluid level
Posted: Sat Aug 24, 2013 6:07 pm
by AndyBaur
I've just been bleeding my brakes with a pressure bleeder. This had left the master cylinder over full. I've removed quite a bit of excess fluid but the "pop-off" valve is still up.
Should this be up or should it be level with the top of the cap?
Re: Brake fluid level
Posted: Sat Aug 24, 2013 6:42 pm
That is not a pop up valve but a level sender, in this case with a ripped top seal. You can order a new cap from the dealer as this will leak like hell and brake fluid is quite devastating stuff
Posted: Sat Aug 24, 2013 7:59 pm
by AndyBaur
Thanks for the heads up!
