Power steering lines
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Post by AndyBaur »
Flushed with success in passing it's MOT (with no advisories!) the Baur has celebrated by splitting the bottom power steering reservoir to pump pipe e_surprised
According to the online catalogue this is a 12 x 18 pipe. This is the same size as the breather pipe on the fuel tank which I replaced recently with proper fuel resistant pipe.
Can I use this pipe or is there something special about the power steering pipes (high pressure/fluid resistant etc.) ?
AndyS
Re: Power steering lines
Should be fine
Yup, no problem to use
AndyBaur
Post by AndyBaur »
That's great thanks.
How much fluid do I need for a good flush? I believe it's Dextron II ATF ? Any other alternative?
AndyS
What else do you want? Most ATF is Dexron DII spec so you can buy it on every corner of the street.
AndyBaur
Post by AndyBaur »
I've never had to buy any so didn't know what the availability was. I'm sure I'd read that Dex 2 had been discontinued. New hi tech oil doesn't work well in old cars & feared the same might be true of ATF.
Will a litre be enough? I want to give the pump a good flush through.
AndyS
