windscreen seal
charlie_e21
windscreen seal
Post by charlie_e21 »
hi im new to here, just bought my first e21 after only owning classic beetles, I have water coming in from somewhere and collecting in both front footwells, im not sure what the common areas would be to check but im going to prob replace windscreen seal first as it seems to be holding water in both bottom corners, (press the seal and water seeps out) which brings me onto my next question, where can I get a decent windscreen seal from?? ideally genuine.. any info would be great, thanks, charlie
arshad76
Re: windscreen seal
Post by arshad76 »
Hi Charlie,
Came across these on ebay. Not sure if they are genuine, but very cheap. Thinking of getting one myself
http://www.ebay.co.uk/itm/181015119768? ... EBIDX%3AIT
UK Moderator
trash-berd
My E21(s): '82 320i US Manual 1.8L
Facebook page: https://www.facebook.com/eli.tripi.5
Re: windscreen seal
Post by trash-berd »
I'm no professional, but everything I've heard from people who know better say it's worth the money to buy windshield gaskets from the dealer. The fit is proper and you won't have to deal with laying silicone sealant everywhere. I ended up paying right around $140 USD for the front gasket and the trim pieces that go in as well IIRC
arshad76
Re: windscreen seal
Post by arshad76 »
trash-berd wrote:I'm no professional, but everything I've heard from people who know better say it's worth the money to buy windshield gaskets from the dealer. The fit is proper and you won't have to deal with laying silicone sealant everywhere. I ended up paying right around $140 USD for the front gasket and the trim pieces that go in as well IIRC
I agree, except I've heard from a reliable source that even though this particular seal by this vendor isn't perfect, it is fit for purpose and ~4 times cheaper than OEM
I suspect for my next project I will go for original seals where available and seeing it costing over a grand :evil:
UK Moderator
charlie_e21
Re: windscreen seal
arshad76 wrote:Hi Charlie,
thanks for reply mate, I did see this one the other day, it would prob be my last resort, would rather get an oem one, just not sure where to look,
charlie_e21
Re: windscreen seal
yeah from past experience with the beetles ive learnt when it comes to seals etc repros generally just don't cut it, never a perfect fit, I will try and find a dealer in the uk which sells them, I would hopefully try and reuse the chrome inserts anyway so would just be the seal so might not be too expensive..
Duracel79
Re: windscreen seal
Post by Duracel79 »
Another option is Walloth & Nesch:
http://www.wallothnesch.com/karosseriea ... 51-02.html
Seems to fit well on Prakash's car. he got the screen rubber and the chromes from them.
http://www.bmwe21.net/forum/viewtopic.p ... 4&start=15
Ben
Eddie.
My E21(s): [O==[][]==O]
Re: windscreen seal
Post by Eddie. »
Get the part number of RealOEM and head over to bmminiparts.
They source genuine items using original part numbers. I've had a few things off them and they're pretty good. Delivery can be a tad hit and miss but they've yet to let me down on finding a part.
trash-berd
Re: windscreen seal
I have no idea how old your chrome trim is, but mine seemed to be original, it was solidified in it's shape (new stuff is fairly flexible). It didn't crack taking out but I bet the possibility is there. Putting the trim back in is a real bitch as well. Don't go out and buy the new trim, but I'd keep a bit of extra money handy in case yours breaks in the process. Pricing in incidentals always is a good call :wink:
fullblast
My E21(s): '78 316 Baur
Re: windscreen seal
Post by fullblast »
Hi,
Sorry for refreshing old topic.
Did someone bought windshield seal from German company Motorform? Did it fit ok?
brockzila
My E21(s): 320/6 1982,
Re: windscreen seal
Post by brockzila »
Yep keen to know of good rubbers. My screen has been glued in to the rubber that's been glued in to the car .It's now cracked
Re: windscreen seal
I'd only buy OEM, too much rubbish around and then you've saved a buck and running into leaks, a broken windscreen, rust of whatever... not worth it
fullblast
Re: windscreen seal
Post by fullblast »
The one i bought from Motorform doesn't fit completely. I could attach couple pictures to show, but don't know how to do it :D
Next time i'll buy Oem too. This time i'll cut it, because need to register car asap.
Mihajlo
My E21(s): 1982 315swap323i
Re: windscreen seal
Post by Mihajlo »
posting videos and pictures - HOW TO -
viewtopic.php?f=2&t=15956
fullblast
Re: windscreen seal
Post by fullblast »
finally
