Ok so my mechanic has a small block chevy sat in his workshop spare
He keeps asking if he can fit it in my 316!
I was talking about going the m50/m52 route and he thinks the chevy would be an easier conversion as no ecu etc
And should have a few more ponies
But has anyone done it or heard of doing it ?
My worry is the weight of the thing - id imagine its a heavy engine
Chevy V8 in my E21?
- TopCat
Re: Chevy
Best engine in the world with nearly 100 million made since 1955
Go for It!
Huge selection of aftermarket alloy heads- I would go for a set of Edelbrock with matched manifold from Real Steel- go small Holley a 390 would do the trick. If you want to show me the engine code- if it is an older one I can decode it to tell if it is a 307 base or a 302 screamer, or a boggo 350.
You can sort out an MSD blaster coil - all requires no ECU programming etc
Go for It!
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Topcat
- mcjjordan
- My E21(s): Uk 1980 316 m52
Re: Chevy V8 in my E21?
How much do they weigh?
How much does m20/m50 weigh?
- mcjjordan
Think it's std as it's the old unit he took out of his street rod - the replacement is supposed to be 450bhp.
- TopCat
The Chev will of course weigh more but will be more set back than the M20 which has at least 2 cylindars in front of front axle line
can't help without codes........................
a good Goodwrench crate engine makes 360 bhp out of the box
Regards
Topcat
Topcat
