323i wheel bearing
Alpina123
My E21(s): 82 323i manual
323i wheel bearing
Post by Alpina123 »
Hi does anyone know where I could get these? One is a 58mm and the other a 62mm seem to be unique to a 323 I've had all the others but they are both 58mm, I have tried most places, can anyone help ?thanks
Re: 323i wheel bearing
I believe 62mm is a separate ring around the inner bearing, inner bearing should be 31.7x59.1x15.8
Alpina123
Post by Alpina123 »
Yeah I've got the 62mm one I can get a 58mm one out of a 318 bearing kit for example but the bore size isn't big enough so won't go over the splines
We did some puzzling a while back and came to the following conclusion, can you confirm this?
4 cyl strut bearings: 29.0x50.29x14.22 & 17x39.87x13.84
6 cyl strut bearings: 31.7x59.1x15.8 & 19x45.23x15.49
There shouldn't be more different versions in E21 struts afaik.
Alpina123
Post by Alpina123 »
This is the rear wheel bearing, seems to be unique to a disc arm I can't find one anywhere
Ahhh rear! That's 1x 58mm and 1x 62mm indeed, version for 320/6 and 323i
