Engine conversions, Easiest swap for a 320/6 and how much?
Mucka
My E21(s): 320
Post by Mucka »
Hi,
My e21 needs a bit of engine work to get it running nice again, the carb needs rebuilding or replacing and it needs new ignition, plugs,leads, rotor arm and cap.
Its a 320/6 78 model but with the price of a replacement weber dgas 38 and the ignition its over £600, thats with out a rolling road tune up.
So I been tempted to change the engine but I don't know what seems to be the best option, value for money, or value for power.
I read up here and some of the posts on here too,
http://www.fritzsbits.co.uk/shop/engine-conversions/
Mine is a 4 speed manual
The only negative I can see is mine engine is only on 67,000 genuine miles original engine.
I appreciate I will need brake and suspension and exhaust upgrades so exclude that from the list for now.
Any input would be great thanks :)
Cheers
Craig
Re: Engine conversions, Easiest swap for a 320/6 and how muc
325i e30 engine. Minimal fuss.
Mucka
My E21(s): 320
Post by Mucka »
Thanks Nas, the e30 engines are cheaper than the price of a dgas carb
Sorry few questions i'm thinking out aloud
What radiator/fan would I use
Would I need to change the rear diff and gearbox?
Would the exhaust manifolds fit to the existing system?
few more would I need a different fuel pump
and my brake servo is mounted behind the head lamp
Mucka
My E21(s): 320
Post by Mucka »
Found this, how accurate is it?
http://www.todor.info/repair/e21swap/
The m20 325 engine swap has been done loads on ere.
Search the forum you'll get everything
