Which is better 4 speed manual or 5 speed overdrive
SSF-323i
Which is better for my e21 323i, I will be using the car for fast road and mild track use, thanks
Re: Which is better 4 speed manual or 5 speed overdrive
On the 4 speeds and overdrive 5 speed the first 4 gears are pretty much similar so the 5 speed will mainly add that overdrive that can be useful for longer trips. If you use a relatively short diff you might need that 5th as well. Sports gearboxes (5 speed dogleg with 1:1 5th gear) give you closer ratios but these are becoming real rare.
SSF-323i
Ok thanks, to be honest I think I prefer the 4 speed as when I place it in fifth gear the revs go much less and the drive is no comfortable , so I'm thinking of switching to a 4 speed box
- PeteK
- My E21(s): 1979 323i Euro
Have you already got a 5 speed installed? If so, changing to a 4 speed would be pointless.
4th gear in both gearboxes is 1:1, so they are the same. The other gears are almost identical as well. If you don't like the feel of 5th gear, just don't use it.
Alternatively, get yourself a lower ratio differential. You've probably got a 3.45. You could change to a 3.91 quite easily and it would increase the revs when you're in 5th gear.
Cheers
Cheers
Pete K
'79 323i (for good times)
'81 M535i (for collecting)
'75 520i (track machine)
'03 320i (for commuting)
'97 Laser
'97 Laser
SSF-323i
Oh okay I'll see if I can get hold of that cheers
- Mihajlo
- My E21(s): 1982 315swap323i
3.45 diif ratio is useless unless you have upgraded engine / *dogleg
I'll reinstall 3.45 diff only if I go to Sharknose meeting...
EDIT *
EDIT *
Not if you have a dogleg3.45 diif ratio is useless unless you have upgraded engine
