I am looking for the correct wheel alignment data for my E21. I couldn't find anything on the forum though. I have a lowered E21 with GAZ coilover, PU bushes all around and camber and caster adjustable top mounts in front. I will use the original wheel alignment data if anyone can point me out to it.
This is the data i found, perhaps anyone can confirm or give an advice about what to change if i wanted it to be more grippy/ sporty.
But if someone has a more sporty setting with adjustable top mounts that would be great.Front toe in; 1.0-2.5mm(0.039 to 0.099 in) to 3/81
1.4-2.6mm(0.055 to 0.102 in) 4/81 on
Camber ; not adjustable, but look for about -1.2 degrees total with camber plates
book says -30' to 30'
Caster -7.5 to -8.6 degrees
Rear:Toe in 1.2 to 2.8 mm(0.047 to 0.110 in)
Camber -1.3 to -2.3 negative
Thanks
