Weber dgas 38 vacuum pipes
Mucka
My E21(s): 320
Post by Mucka »
Hi
Just wondering if any one can confirm where the vacuum pipes from the Weber dgas connect to?
The carb has 3 outlets for vacuum but the dizzy only has 2.
On the dizzy which is the advance the front one and the rear is the retard?
Thanks
Tato
My E21(s): 1980 E21 316/1 manual
Re: Weber dgas 38 vacuum pipes
Post by Tato »
Pictures?
1980 316/1
David Mc
Post by David Mc »
On the dizzy, the retard hose (originally a white hose) is the one closest to the distributor body and the advance (originally a black hose) is on the outside.
Mucka
My E21(s): 320
Post by Mucka »
Thanks, I got this working a little while ago it been running the best ever, the idle is a little high 1400rpm but it drives so nice
David Mc
Post by David Mc »
When the engine is warm and running, pinch off the air hose that runs between the additional air slide and the intake manifold. If the idle drops, the problem is your additional air slide stuck in the open position.
