Weber dgas 38 vacuum pipes
Posted: Fri May 08, 2015 8:59 pm
by Mucka
Hi
Just wondering if any one can confirm where the vacuum pipes from the Weber dgas connect to?
The carb has 3 outlets for vacuum but the dizzy only has 2.
On the dizzy which is the advance the front one and the rear is the retard?
Thanks
Re: Weber dgas 38 vacuum pipes
Posted: Fri Jun 05, 2015 5:42 pm
by Tato
Pictures?
Posted: Mon Jun 08, 2015 11:21 am
by David Mc
On the dizzy, the retard hose (originally a white hose) is the one closest to the distributor body and the advance (originally a black hose) is on the outside.
Posted: Mon Jun 08, 2015 10:57 pm
by Mucka
Thanks, I got this working a little while ago it been running the best ever, the idle is a little high 1400rpm but it drives so nice
Posted: Tue Jun 09, 2015 12:01 am
by David Mc
When the engine is warm and running, pinch off the air hose that runs between the additional air slide and the intake manifold. If the idle drops, the problem is your additional air slide stuck in the open position.
