Master cylinder
mcjjordan
My E21(s): Uk 1980 316 m52
Master cylinder
Post by mcjjordan »
Just found my master cylinder has been leaking fluid into servo
Am i right in thinking they are no longer servicable?
Anyone got anyways around this problem?
Was thinking servo & cylinder from another model...
Re: Master cylinder
search
function
brake
master
overhaul
:roll:
viewtopic.php?f=3&t=23073&p=245939
jimbob
Re: Master cylinder
Post by jimbob »
I got a seal set from http://www.biggred.co.uk/ for the master cylinder
They are very helpful if you call them.
E36 328i Daily driver
E36 328i Touring
mcjjordan
Re: Master cylinder
Post by mcjjordan »
David Mc
Re: Master cylinder
Post by David Mc »
That's doing things the expensive way - if you can get the seals, take your master cylinder into a master cylinder repair shop (or engineering works) and get them to sleeve the original with a stainless steel insert. I have had this done on numerous cars and tractors over the past 30 years and have never had to touch a sleeved unit again!
mcjjordan
Re: Master cylinder
Post by mcjjordan »
I spoke to pastparts who do that service and it was more expensive!
Re: Master cylinder
I've repaired a few now using replacement seals. It's easy. As Jeroen said there's plenty of info on this.
Once I found a new old stock lhd one for dirt cheap and I used the internals in a rhd one, worked fine.
I haven't had to 're sleeve one ever but thats a bloody good idea actually didn't know you could do that!
Reck
Re: Master cylinder
Post by Reck »
Why resleeve? To stop the pitted walls shredding the new seals?
Re: Master cylinder
Yea that's it.
Gazman
My E21(s): 1981, Reseda green 323i, manual.
Re: Master cylinder
Post by Gazman »
I had my master cylinder stainless sleeved and refurbished By Fritz's bits. Was about £210 and took 3 weeks to turn it around but it was a good job, it came back better than new.
“The fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.”
― Bertrand Russell
