Master cylinder
Posted: Thu Oct 22, 2015 12:00 am
by mcjjordan
Just found my master cylinder has been leaking fluid into servo
Am i right in thinking they are no longer servicable?
Anyone got anyways around this problem?
Was thinking servo & cylinder from another model...
Re: Master cylinder
Posted: Thu Oct 22, 2015 12:24 am
search
function
brake
master
overhaul
:roll:
viewtopic.php?f=3&t=23073&p=245939
Re: Master cylinder
Posted: Thu Oct 22, 2015 11:20 am
by jimbob
I got a seal set from http://www.biggred.co.uk/ for the master cylinder
They are very helpful if you call them.
Re: Master cylinder
Posted: Fri Oct 30, 2015 3:12 pm
by mcjjordan
Re: Master cylinder
Posted: Fri Oct 30, 2015 5:42 pm
by David Mc
That's doing things the expensive way - if you can get the seals, take your master cylinder into a master cylinder repair shop (or engineering works) and get them to sleeve the original with a stainless steel insert. I have had this done on numerous cars and tractors over the past 30 years and have never had to touch a sleeved unit again!
Re: Master cylinder
Posted: Fri Oct 30, 2015 5:58 pm
by mcjjordan
I spoke to pastparts who do that service and it was more expensive!
Re: Master cylinder
Posted: Sun Nov 01, 2015 8:33 pm
by nas80
I've repaired a few now using replacement seals. It's easy. As Jeroen said there's plenty of info on this.
Once I found a new old stock lhd one for dirt cheap and I used the internals in a rhd one, worked fine.
I haven't had to 're sleeve one ever but thats a bloody good idea actually didn't know you could do that!
Re: Master cylinder
Posted: Mon Nov 02, 2015 4:42 pm
by Reck
Why resleeve? To stop the pitted walls shredding the new seals?
Re: Master cylinder
Posted: Tue Nov 03, 2015 11:09 pm
by nas80
Yea that's it.
Re: Master cylinder
Posted: Tue Nov 24, 2015 10:16 pm
by Gazman
I had my master cylinder stainless sleeved and refurbished By Fritz's bits. Was about £210 and took 3 weeks to turn it around but it was a good job, it came back better than new.
