1980 323i wiring diagram
nickylemns
Post by nickylemns »
Hi everybody. I have been searching, and it seems all I can find are dead links or the diagrams for 320's. I have a haynes manual for the E21, but the entire 323i section switches over to the e30. I am chasing about a million different shorts in the system...
Re: 1980 323i wiring diagram
Part of the factory repair manual that is available to our VIP members
Further, I may bump into an intact LHD 323i wiring loom shortly. Just shipping might make it expensive.
nickylemns
Thanks Jeroen. Love to become a VIP member, money sent! As for the LHD wiring harness, if you do end up coming across that LHD harness let me know. I still do have faith that mine could be salvageable but only a little bit of time will tell. Looking forward to viewing the content. Thanks again.
All set up, thanks from this side as well! Let us know if you keep having issues and on my turn I will keep you posted when a wiring loom crosses my path.
nickylemns
Do you know if there is a difference between the wiring diagram for RHD vs LHD, or is the information generally the same?
Well the layout should be the same, but cable lengths will be different for several items. Both diagrams are in the factory manual btw! Was that manual of help?
Sanjay Seetanah
My E21(s): 1981 323i Baur Cabriolet
Post by Sanjay Seetanah »
Hi,
Hope that it's okay jumping onto this thread as I didn't want to start another one. I am having my RHD '81 323i Baur stripped for a respray, the engine is out. As I had been having several issues with electrics, mainly with slow wipers, poor lights, erratic heater and various things like that, I wanted to know if you would advise changing the wiring loom? If so where can I get one or will it have to be a bespoke remanufacture?
Thanks
Sanjay
fastbmw
My E21(s): '81 baur 320 manual
Post by fastbmw »
hi folks, does anybody have a wiring diagram for a 318 LHD, '81 modell?
e21Keith
My E21(s): '81 323i Manual
Post by e21Keith »
Having installed a 318 loom in a 323i can tell you that the differences are very minimal, from memory the headlights, fuel pump, engine loom and the brake pad sensor for the rear pads, indeed all these connections were in my 318 loom so it was all plug and play. The fuse box is different and I replaced mine with a new one, still available from BMW. Replacing the fuse box fixed all the problems I had with lights not working.
You can download a copy of the factory manual in the vip section as a pdf and the diagram is included.
