idle problem
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
idle problem
Post by cobbler2u »
Car starts and run's well.
Until it warms up. Then the revs fall and the car stalls all the time.
Could it be warm up regulator or fuel regulator.
Iv'e changed the temp switch.
Re: idle problem
Check the idle adjustments, especially CO, and check for vacuum leaks.
cobbler2u
323i special
328 sport
325i
Re: idle problem
Post by cobbler2u »
Thanks
would the idle not be to high if adjusted once car is hot.
As idle is fine when cold,
Re: idle problem
nope, idle and CO need to be set warm. During the warmup phase the WUR needs to take care of extra fuel and the aux air valve should raise idle rpm.
cobbler2u
323i special
328 sport
325i
Re: idle problem
Post by cobbler2u »
:thumbsup
What should our cars run at
idle 900rpm
co ?
