E 30 electronic speedo
healeyneil
- My E21(s): '81 318is Baur - ahead of its time !
Does anyone know what sort of signal the sender for one of these should transmit ? My adapted speedo isnt working. I put a trigger wheel on one driveshaft and mounted the sender to suit, but no joy, so my first thought is to put a voltmeter on the signal wire. Any thoughts ?
Thanks, Neil
Thanks, Neil
Re: E 30 electronic speedo
You'll need a square wave signal from the sender unit, the sender unit needs to have a open collector or open drain output to ground. about 9 pulses per wheel turn.
Hope this helps
Hope this helps
healeyneil
Ah well, thats me stuffed then ! I can just about run checks with a voltmeter !
What kind of pulsesender and triggerwheel have you tried?healeyneil wrote:Ah well, thats me stuffed then ! I can just about run checks with a voltmeter !
healeyneil
The sender is an E30 one removed from a diff, and the trigger wheel I made myself, copied from the dimensions of an original. I think I need to review my wiring !
did some googling:healeyneil wrote:The sender is an E30 one removed from a diff, and the trigger wheel I made myself, copied from the dimensions of an original. I think I need to review my wiring !
Okay, that sensor type is fairly simple, in fact it is nothing more than a switch. one leg in the sensor contains a magnet and the other leg a reedcontact, which is a switch operated by magnetism.
So you could first test the sensor with your multimeter. Put the multimeter in Resistance, and hook up to the sensor. while turning the triggerwheel slowly, the resistance should swap from zero to infinite and back. If it is realy silent you should be able to hear the sensor switching. A reedcontact makes a very soft clicking sound when operated.
If sensor ok then check your wiring to the dash.
good luck.
healeyneil
I will do that at the weekend. Many thanks, Neil
Have you got power and earth to the speedo itself as well as the signal wire?
My E24 electronic speedo needed:
1 - 12v power
2 - Earth
3 - signal wire to the sensor, then the other side of the sensor goes to earth.
Hope this helps
Ben
1 - 12v power
2 - Earth
Hope this helps
Ben
healeyneil
Tests done , and it looks like my sender is dead. Thanks for the suggestions
Neil
Neil
