What is the internal diameter of the front struts for a 1982 323I? Would it be 45mm?
Thanks.
Yatis
Internal diameter of 323I struts
Re: Internal diameter of 323I struts
quoted off bimmerforums.... :
320i 45mm strut od, uses a 38mm insert (shock) which has a piston size 30mm
323 51mm strut, uses a 45mm insert, and has piston size of 36mm.
Thank you. This information is exactly what I wanted.
Yatis
Yatis
