leaky injectors....
bimmerfane21
My E21(s): 81 320i e21
leaky injectors....
Post by bimmerfane21 »
my injectors that are only a couple years old at the most are leaking and not opening at the same time.
i have flushed my injectors.
i pulled the poppet out wit a small wire very carefully, clamped a hose on the injector and back flushed it to get rid of anything in there, and they still leak just as bad.
i was very careful when putting the wire around the injector poppet to pull it out a little to flush them.
any ideas worth cleaning again or need new injectors
Re: leaky injectors....
Probably the seals are pretty much dead after 35+ years of service. It's not cheap but replacing them with new ones is the only option left if a thorough and careful cleaning didn't help.
bimmerfane21
they are only a couple years old
Oh sorry for overlooking that! That is really weird. Puzzled as much as you are now!
bimmerfane21
Shameful. Ill keep trying to adjust mixture screw slowly and dist to get it going again as from previous post. Hoping to get her to start again
