ST sway bar kit doubt!!! 25mm/19mm
Moutinho
My E21(s): ´79 Euro 320/6 5speed Manual
Post by Moutinho »
hi guys, i own an euro 1979 320/6 and i want to upgrade my sway bars 19mm front/16mm rear to 25mm front/19mm rear ST sway bar kit!
i heard that that kit wont fit pre 80´s cars, is that true?
Need help pleaseeeee!!! :M20
Re: ST sway bar kit doubt!!! 25mm/19mm
early ones had a different sway bar and trailing arm geometry I believe. Changeover was production Oct 78 according to BMW ETK, so in that case you should be ok.
Moutinho
Post by Moutinho »
That was the greatest new you could possibly give me.
Thanks Jeroen :shake :boogie
Jep, mine is a november '78 323i and has the newer sways.
Moutinho
Post by Moutinho »
Thank God! :banana anyway, i'm going to check my subframe and try to understand if is the earlier or the late model! Everything points for the later model!!! :driving
With a 79 I wouldn't worry and it's hard to see anyway.
Moutinho
Post by Moutinho »
Thanks for the help guys!!! :thumbsup
