If you find the markings "T" or "BO" on it, its a M10 sport.
If you find the markings "GH", "ME" og "GL" on it, its a M10 overdrive.
Like this:
Check out my write up:
http://www.bmwe21.net/forum/viewtopic.php?f=38&t=13418
245 M10 five speed Sport:
245/2.00 T (part number 23001205711)
245/10.00 BO (part number 23001207146)
Recognised by:
- three piece case
- Mechanical speedo output
- Shift pattern: 1st down left, 5th bottom right, reverse same
- Markings should include "245" (follow by more numbers), six unidentified numbers, and the letters "T", or "BO".
- 87mm longer than the 4 speed (requires shorter drive shaft part number 2611120860)
- Four or three bolt output flange 23211208536 or 23211209612
- 120mm between the two top bolts of the bellhousing, as opposed to 140mm for M20 boxes.
- the two top bolts of the bellhousing are M8 (as opposed to M12 on M20 transmissions)
- reverse light switch up top
245 M10 5 speed Overdrive:
245/4.30-GH (part number 23001209775)
245/5.30 ME (part number 23001220421)
245/4.13-GL (part number 23001209891)
Recognised by:
- three piece case
- Shift pattern: as 4 speed, 5th top right
- Markings should include "245" (follow by more numbers), six unidentified numbers, and the letters "GH", "GL", or "ME".
- 87mm longer than the 4 speed (requires shorter drive shaft part number 26111208608 (same as sport))
