New battery, No crank, no lights, no nothing...
coopersguy
My E21(s): 1982 323i
Post by coopersguy »
Hi,
I have an 83 323i. Drove into garage last year. Now with a fresh new battery, no crank, no lights. Absolutely quiet. Fusible link? If yes, where is it? or replace all relays in engine fuse box?
Thanks for your help! :(
Re: New battery, No crank, no lights, no nothing...
Check your ground connections .. they can give some hasslte as well .. bad connection in the fuse box can also be a problem like you mentionned yourself.
Did the car sit for a year in a dry garage ??
Good luck
Clean all your fuses and the terminals
And your grounds too.
E21-driver
My E21(s): BMW E21 315
Post by E21-driver »
...and remove and clean ground connection between engine and chassis..on lh front arm.
1982 315 reseda
