old tyres !
healeyneil
old tyres !
Post by healeyneil »
I decided to go back to the original 13 steel wheels, so got them blasted and painted. To see how the car felt, the original tyres went back on. Although old, there were no cracks, etc. Within a hundred miles or so, this happened Image
Side wall distorted too, but still holding air. As the ride has improved - as you'd expect with the higher sidewall, Im sticking with the 13"s. New set of tyres on order, all I need now is a spare !
Mihajlo
My E21(s): 1982 315swap323i
Re: old tyres !
Post by Mihajlo »
take that tyres off ASAP unless you want to kill yourself or buy new panels...
healeyneil
Re: old tyres !
Don't worry. I won't even drive to the tyre fitter on them !
Re: old tyres !
Oops! :P
runsub5
My E21(s): Original US 1979 320i Manual 4 speed
Re: old tyres !
Post by runsub5 »
Where were you able to buy 13 inch tires?
David
Re: old tyres !
Probably varies by the country but over here in Holland you can still buy them, but there's less and less choice of proper quality rubber. Same as with 15".
runsub5
Re: old tyres !
Post by runsub5 »
Jeroen wrote:Probably varies by the country but over here in Holland you can still buy them, but there's less and less choice of proper quality rubber. Same as with 15".
I am located in the U.S. I did find a company in the UK selling classic tires. Here's the link.
https://www.longstonetyres.co.uk/tyres/185-70x13.html
David
Mihajlo
Re: old tyres !
Post by Mihajlo »
I guess any tyre supplyer should be able to order 13" if there is demand to....
avon or toyo are pretty much okay and they are stil in business with 13" :)
