Hi,
my 320 has just started that characteristic clicking noise at low speed, suggesting a rear wheel bearing is on the way out.
How difficult it to replace these?
any tips on the job would be appreciated.
cheers
Mike
Rear wheel bearing
Mikelead
- E21 starter
- My E21(s): 82 320/6 manual, U.K. Rhd
Re: Rear wheel bearing
How easily does the splined hub flange come off?, will a 3 leg puller do this in situ, or is it necessary to use a press?
Mike
Mike
Anyone experienced here? Not me I'm afraid, not with rear wheel bearings.
No need to use press. 320/6 have same bearings as 323i,so make sure buy right ones.
Make sure that there is 0,1 mm (at least) bearing play otherwise bearing wears fast.
Full factory manual in English and Dutch available for VIP members
