E21 with Busso engine
Torbey
My E21(s): 79 US 320i manual
Post by Torbey »
I know its a weird one but read till the end please,
I got my hands on a Alfa 166 for cheap with the lovely Busso engine the 3.2 version, the car is in a very bad shape in every single way
I am planing to take off the engine for a full rebuild , but I want to RWD this engine in a bmw E21 body that I do have laying around ,
The alfa engine is around 135KG so I its not heavy, with output of around 240HP which is almost an overkill on a e21 chassis ,
Do you have any advise before starting this project this is my first alfa x bmw mating , I have good mechanical background but I am bit worried on the wiring side of things, and making things like gauges and so on work normally when mating .
Any coment would be helpfull, cheers
Sorry for my english
Re: E21 with Busso engine
Can't help you out with any expert advice but yes that is a great looking and sounding engine, and not bad when it comes to performance and reliability afaik. So even though people might see this as sacriledge I would definitely like to follow this if this becomes an actual project!
Torbey
Post by Torbey »
Trying to find suitble trans. as all busso engine are either fwd or a transaxle,
I will be removing the alfa engine by next weekend,
A cool project. Busso engines are great, topsound, good revhappy. Looking forward how you are going play this.
Indeed, should be a nice project.
About gauges, the E21 only has a temp gauge, rev counter and the idiot light. Rev counter shouldn't be a problem if you take a e21 6 cyl rev counter.
Temp gauge has only a 1 wire sensor which is used on a wide variaty of cars, probably the sensor wil fit your busso engine somewhere.
The rest of the electronics come from the 166 ofcourse.
I should try to mate the engine with a adapter plate to a stock e21 gearbox, least problems with clutch, gear selector, propshaft and speedo cable.
Torbey
Post by Torbey »
Any advise on the body or chassis upgrade, that I should worry about
Torbey wrote: Mon Apr 20, 2020 10:39 pm Any advise on the body or chassis upgrade, that I should worry about
Just brake upgrade will do, the old bmw chassis are well build and very stiff compared to other cars from the same era.
