Custom rebuilt E21
e21est
My E21(s): '83 EU manual
Custom rebuilt E21
Post by e21est »
I'm starting my E21 project from basically scratch.
Mostly making this thread so it's easier for me to keep track.
Anyway the car was a real sh*t box, which i got for cheap since i did not want to cannibalize a great example for what i have planned. Also it's quite hard to find something with a nice chassis.
I guess its a bigger project than i realized but it is being done in probably record time since i stripped this car in february and got it mediablasted also in february. Lucky its an easy car to dismantle.
First things first.
I stripped it down to bare chassis and media blasted bottom end with glassbeads to see what's up.
Blasting revealed that the body is not in great condition and would have been easier to just take another project but since already started on this might as well finish...
Ordered a lot of replacement body panels from Valcasgarage which are now being welded in (basically everything they had to offer).
Right now trunk floor(along with parts of wheel well), basically whole interior floor, rear axle mounts (made stronger), inner and outer sills have been welded. Rear quarter panels are currently being welded. Front end is basically half cut away and half-frame rails are being welded in from stronger steel (CNC laser cut).
Deleting the spare wheel tire area to get more room underneath.
I'm probably going with M54B30 engine for this, haven't bought it yet but i have bought E21 M50 engine mounts from E28goodies and I have sourced an E34 M50 oil pan for this purpose already. I first figured of doing M42 turbo or something like that, then thought about M20 but i changed my mind due to lighter weight and smoothness of M54 being far superior.
Since I do not like the type168 differential I'm going the route of type188 and for that purpose i'm modifying an E28 rear axle to fit E21. I'm also welding in toe&camber adjustment plates so it's possible to adjust the rear end (already bought a kit). I have already sourced the E28 rear axle which has thankfully already been sandblasted and painted and is the bigger type with dogbones. Differential is not great, i would like a better ratio but it will have to do for now. Probably going with E34 520i/525tds rear cover along with the bushing since it sits a little bit lower than E28 rear cover. I have already sourced those as well. E34 rear brakes.
Rear axle bushings are going to be poly with 80 hardness since i could not find new rubber ones.
image upload
Re: Custom rebuilt E21
Wow, welcome here! What a way to start off, my compliments! And you'ree not sitting around wasting time either haha! Looks like you've done quite a bit of homework and shopping already, all 'n all looks and sounds good!
If the car is not going to be stock then a slightly more modern engine is a really good option. The M54 is smooth and powerful, as an alternative you may want to consider the M52B28, probably one of the best power plants ever made in Bavaria. Slightly down on power compared to the M54B30, but they seem to last forever and don't have -for example- the oil consumption issues that frequently hamper M54's.
BMW had their reasons to keep the official power figures of the M52B28 on the conservative side, but with an M50 intake these engines easily produce 220 BHP, and that's not far off the values for the M54B30.
Great, a new project here. Good luck and succes with that! Can't wait to see the next update. Like Jeroen says, you're hauling ass!
e21est
Post by e21est »
I know about the issues plaguing the M54 but for me that's a non-issue since I plan to strip the engine and rebuild it completely at some point anyway(new rings, bearings, oil pump system, cylinder head rework etc).
I also like the idea of electronic throttle control instead of cable and the non-return fuel system.
M52 is great and all but if i rework the engine then makes more sense to go M54 route for now.
RIght now i'm trying to find 320i front struts for a reasonable price so i could run the smaller shock from 318i (since these are still being sold aftermarket) but run E12 5x120 bigger hubs and brakes. Front brakes i will try the route of late E24 disks and opel omega A calipers. Over here they do not like brake modifications much so brackets are something i'm trying to avoid for now.
Main issue is that there aren't a lot of them for parts and even less 320's over here.
e21est
Post by e21est »
A light update. Rear arches welding is done, floor is almost done, i have to source and fit E28 stabilizer. Front end is still in progress.
E28 rear axle along with adjustment plates has been welded and has been test fitted.
Probably need to roll the arches or modify arches another way since the axle takes quite a lot of space.
e21est
Post by e21est »
Welding is basically done. New halfframe rails from twice the material from original.
Moving on to painting and bodyworks soon.
create 2x2 picture online
:thumbsup :thumbsup :thumbsup :thumbsup
Nice!!!
e21est
Post by e21est »
Not much done right now body work wise, found 320i front struts and E23 hubs to go along with them. Also bought some lowering springs for the car.
I'm going to put in F30 seats since i have them laying around and later will upgrade to sport seats from F32 probably. I have seen F30 sport textile seats in E30 and they didn't look far off and were actually pretty light and comfortable.
Made a choice for the wheels and bought tires already aswell, have to get the rear fenders built/rolled before painting.
I was going along with a friend to another country to buy a car and found a engine/equipment donor for the E21. The car is RHD and was from UK, where it was owned supposedly by an car enthusiast and has not seen road salts of the Baltics. Engine has 200k on it and is clean of oil and runs pretty well. It is an M54B25 though instead of M54B30 which I originally wanted but at some point I'm throwing a rebuilt M5430 in it anyway, right now i want to get it driving in summer and i want to keep it somewhat in the budget, M54B30 is 3-4x more expensive than M54B25 over here. I'm also getting a 5speed Getrag, wiring loom etc, it's easier to build if i have a parts donor. Got it for pretty cheap so i will probably get close to zero after selling the rest of the car for parts.
Nice plans!
You have the speed in your project!
Do the E23 hubs fit directly? I have 320/6 struts. Small diameter tubes but large diameter bearings.
e21est
Post by e21est »
Should fit directly yes, I need to clean them off of rust which i plan to do next week and then will try.
I have the same struts.
This week I managed to disassemble the E39 almost completely and sold most of the parts already. So the next week will try to get the struts and axles together.
So I tried electrolysis on the front struts since I have always wanted to do this.
Unfortunately I lost the picture on how it was before but they were pretty heavily rusted.
The picture is after 24hours of electrolysis and spray painted afterwards.
e21est
Post by e21est »
Car still waiting for body works but I found out that my front struts are from 323i since they are 51mm outer diameter.
Since I can't find 323i shocks (and i do not want to pay 700€ for bmw shocks) does someone have experience with E30 strut inserts in E21 323i strut?
Bilstein B6 and B8 both available in 51mm E21 spec from Autodoc. And WallothNesch probably have some options as well.
e21est
Post by e21est »
Haven't measured or tried yet but i managed to find some NK shocks (made in spain) for 24€ both which according to code should fit(They are 320 323i shocks). Probably end stock items, package looked worn. Outer diameter for shock insert was 45mm at top which i found from some forum should fit 323i strut.
Anyway 24€ is cheap enough that I won't bother returning anyway.
Still waiting for painting but the axles are mounted for now. Rear is E28 axle, the wheels are from the same E39 with lower profile tires. Initially the wheels I only planned to use on the car to move it around but I'm starting to like them a bit so we will see.
Of course no engine installed or diff installed yet so sits quite high for now.
