rear brake sensor
relulu
rear brake sensor
Post by relulu »
i replaced my rear brakes, and the rear brake sensor. Does anything need to be done in order to turn off the light in my dash?
- I turn on the switch and let it for 4 mnts , and did nothing !!
- I took off the battery and did nothing !!
- I changed the sensor with another one , and did nothing .
when i connect the sensor , the light didn't go off but go weak and strong lighting , which let my Ac and ventilator fuse to be burned !!
I will go tomorrow to BMW agency to see ... but is there any one faced the same thing ?
Check the wiring that's entering the passengers compartment right next to the shifter, it is known to cause short circuits as the wire insulation starts to wear off...
relulu
Post by relulu »
Aren't you the genius ? :wink:
Well , they used G1 machine , and they found nothing !! every thing in it place , but I opened to see the wiring that's entering the passengers compartment right next to the shifter ( just as how you said ) , well, there was an wire was uncovering and touch another one .. which caused all the problem .
I will post soon the pic for my lovely 320is :D
Good to hear!
relulu
Post by relulu »
:D
I don't know where to post the pic , so i will post it here ! 8)
My lovely brother and my lovely car :)
[img]http://img96.imageshack.us/img96/5935/cimg0556.jpg[/img]
[img]http://img94.imageshack.us/img94/2380/cimg0559.jpg[/img]
